I have the attached labview project, settings on a shared variable and block diagram. In my project I have a cRio that is using scan engine and reporting some RTD temps. in My Computer I have a shared variable that I aliased to the scan engine variable on the cRio. I thought this would make it so the shared variable on myComputer would report out the same as the scan engine variable on the cRio; however, that is not the case. In the front panel you can see I get 0 for the myComputer shared variable while getting the correct value from the cRio scan engine variable.
Does binding a variable to a scan engine variable mean it will keep the same value? Do I need to do anything extra? I want to do it this way becuase I have a VI that finds all variables in the SystemParameter.lvlib file and does some stuff with them.
