Thanks you, for your time.
Computer description system:
- PIII 800 MHz, 128 Mb, 10 G HD, graphic card of 8 Mb.
- Windows NT 4.0 SP 6.
- 580 tags, but I must refresh 30 tags (analog and digital)only, and the other tags are used for PLC configuration. But they must be declared.
When I define 16 digital tags my refresh time is nearly 1 second. These tags are defined in the same DB.
If you need the SCF file, I will send you.
Jorge.
