Bi-directional SSH communication
So far so good!  Now for the next hurdle which, hopefully, doesn't inconvenience you.  Thanks again for the promt replies!!!
Message 11 of 13
(1,286 Views)
Great, Glad I could help.
Message 12 of 13
(1,281 Views)
Resurrecting this thread as I need to solve the same issue.  I need to replace some code that uses standard TCP connect, write, read, disconnect with the equivalents for an SSH connection.  This solution looked good but I need the version that does not append the CR to each write.  Was that updated DLL posted somewhere?
Also, I need to know if this solution is reentrant.  I need to open multiple simultaneous SSH connections to different servers and communicate with them on different threads in my LabVIEW application.  I have not been able to find any info on the web stating that the core ssh.net library that Greg wrapped here is thread safe and reentrant.
Thanks for any info/help with this.
-John
Certified LabVIEW Architect
Message 13 of 13
(733 Views)
