Resurrecting this thread as I need to solve the same issue. I need to replace some code that uses standard TCP connect, write, read, disconnect with the equivalents for an SSH connection. This solution looked good but I need the version that does not append the CR to each write. Was that updated DLL posted somewhere?
Also, I need to know if this solution is reentrant. I need to open multiple simultaneous SSH connections to different servers and communicate with them on different threads in my LabVIEW application. I have not been able to find any info on the web stating that the core ssh.net library that Greg wrapped here is thread safe and reentrant.
Thanks for any info/help with this.
-John
Certified LabVIEW Architect
