06-22-2016 09:24 AM
So far so good! Now for the next hurdle which, hopefully, doesn't inconvenience you. Thanks again for the promt replies!!!
06-22-2016 10:46 AM
Great, Glad I could help.
04-10-2019 01:20 PM
Resurrecting this thread as I need to solve the same issue. I need to replace some code that uses standard TCP connect, write, read, disconnect with the equivalents for an SSH connection. This solution looked good but I need the version that does not append the CR to each write. Was that updated DLL posted somewhere?
Also, I need to know if this solution is reentrant. I need to open multiple simultaneous SSH connections to different servers and communicate with them on different threads in my LabVIEW application. I have not been able to find any info on the web stating that the core ssh.net library that Greg wrapped here is thread safe and reentrant.
Thanks for any info/help with this.
