Best way to change up to 20 controls on the main VI from a subVI
@winstroth wrote:
Now I face another Problem, I want to bundle all my control references into a cluster but I cannot figure out how to do it.
Sry, I am kind of new to Labview.
Thx
Jan
Right-click the control reference, select "create constant", copy the constant to the cluster.
Br,
/Roger
Message 11 of 19
(649 Views)
Thx
Jan
Br,
/Roger
A short-cut to help create the cluster in the first place is found in this Nugget that exploits the little used middle input of a bundle (not a bundle by name, that comes latter).
Here is a preview
But you will have to llok at that nugget to get the full story.
Ben
PS I would like to offer a special shout-out to Greg McKaskle for giving me that idea.
Message 12 of 19
(630 Views)
You can use a reference of your cluster to change the properties of the controls inside by using the "Controls[]"-Property of the cluster. You can for example change the disabled-status of all your controls by the attached diagram.
For this, you have to use a property that all controls have in common. Special properties like for example cursor lists of a graph can't be changed this way as not all controls have this property.
Another interesting thing to mention: If you use your controls in a cluster, you can't access an individual control's value without unclustering. Positioning the controls on a tabbed-page control, you have control to the individual controls on your block diagram, but you can also use the reference "Controls" of your tab page for accessing the properties of all controls...thus combining the advantages of a cluster with an easier to program access to the individual controls.
Hope this helps,
best regards,
Christian
THINK G!! 😉
Using LabView 2010 and 2011 on Mac and Win
Programming in Microsoft Visual C++ (Win), XCode (Mac)
Message 13 of 19
(608 Views)
Cschneider wrote :
"If you use your controls in a cluster, you can't access an individual control's value without unclustering"
The very simple example I've given here did it !
Cschneider wrote :
"you have to use a property that all controls have in common"
No, if you are able to identify a control (by its name for example) you may read or write specific properties by casting the reference to a less generic one.
HL
Message 14 of 19
(599 Views)
HL
Agreed!
See this Nugget for more on casting unknown refs.
Ben
Message 15 of 19
(590 Views)
No, you also have to access it by some "sort" of unclustering, in this example by using the indexing of the for loop...what I mean is the following case:
As you can see, you can access now the individual controls by their terminals AND by a common reference, another way of grouping VIs without using clusters.
Yes, you are right...but as you said, for this, you have to cast your reference to a more specific class where you have to identify the class of your control somehow...
Christian
THINK G!! 😉
Message 16 of 19
(583 Views)
Christian
Yes see the Nugget i linked above to see one approach.
Ben
Message 17 of 19
(575 Views)
Cool code Ben! Have to have a look at it!
THINK G!! 😉
Message 18 of 19
(572 Views)
Pass your Main VI reference to a SubVI and see the example attached.
Message 19 of 19
(553 Views)
