02-07-2012 04:42 AM
I am facing a problem with my labview code. I have analog/ digital input as well as output. One of my output is kind of PWM which depends on one input. for an example, PWM signal depends on current. How to control PWM based on current value? any suggestion will be helpful.. thanks in advance
02-07-2012 01:18 PM
You've posted into a lengthy 3 1/2 year old thread that hasn't had a post to it in over a year.
You will need to post your message in a NEW thread to really expect to be able to get help.
Make sure you add some details in your message. Right now, the only thing you tell is you have and analog input, digital input and an output. PWM and a problem with your LabVIEW code.
What is the actual problem with your LabVIEW code? It helps if you actually post the code so people can see what you are doing.
