05-10-2004 04:28 PM
01-14-2013 03:13 PM
I leave an example which can contribute, Greetings
01-14-2013 03:30 PM - edited 01-14-2013 05:54 PM
You just responded to a thread from the year 2004 with an example that has some serious problems:
01-14-2013 04:22 PM
thank you very much for the bounding, the objective of the forum is to help only propose a simple example that anyone can understand, there will always be people who are just starting, Greetings
02-23-2017 09:49 AM - edited 02-23-2017 09:51 AM
Carlos, thanks for that example.
I have something to similar to your code. In my case I'm playing a .Wav file after a certain flag is tripped to indicate the occurrence of a event. However, I cannot seem to get the same performance once the code is compiled as a Source Distribution (as a .llb, which is what I want) or as an Executable.
Any thoughts?
I'm away that this thread is from 2013, but any help is appreciated.
02-23-2017 04:20 PM
@hkd2015 wrote:
Any thoughts?
Yes. First, do not continue this decade-old thread!
Start a new topic. Give it a title that pertains to your question (which is not "Beep", right?). If you've tried something and it doesn't work well, attach your VI so others can see what you've tried, get a better idea of what you are trying to do, and can make helpful suggestions or "improve" your code.
02-23-2017 06:36 PM
@Bob_Schor wrote:
@hkd2015 wrote:
Any thoughts?
Why?
I have, but thank you anyway.
02-23-2017 07:52 PM
Why? Here's several reasons.
1) It's poor etiquette on any forums you'll ever visit.
2) The user you're asking questions hasn't had any activity in nearly a year. They're very unlikely to respond to you.
3) Posting to other threads to ask your question is often considered rude as it's hijacking the thread with your needs instead.
4) Posting to another thread is generally only somewhat relevant to your problem. You have something you want solved. People can give you better advice if you have a focused issue to look at rather than trying to split attention across the multiple problems.
5) It's actually worse to post your own thread and then hijack/bump another. It splits any potential help you'd be receiving rather than letting people collaborate to help you out.
Reason enough?
