Battery validation using LabVIEW and PXIe-4144 SMU
Hey,
I am designing Battery validation by using LabVIEW And PXIe-4144 SMU, I Want to Develop test Model for 3.3V  battery. What are all the things i can validate and How?
Swapnil
(3,052 Views)
Hi Swap,
Read the spec sheet of your "3.3V battery" to learn about all those things you can "validate"…
What is your exact requirement?
(2,187 Views)
Hi GerdW,
Thanks for reply on my query,
I will check specs of battery.
I am working on it will come back to you.
Swapnil.
(2,172 Views)
The requirement is as below
1. I want to charge the battery with a charging voltage of 3,2V and a charge current of 3mA.
2. I want to load the battery by
                          a) pulse with a pulse current of 45mA with a specific pulse width
                          b) pulse with a pulse current of 15mA with a specific pulse width
3. Need to monitor below parameter
                           a) Battery voltage
                           b) sink current
                           c) charging time
                           b) discharging time
Please let us know if PXIe-4144 can be used for the above requirement.
Soumya
(2,159 Views)
Hi swap/soumya,
according to its specs the PXIe4144 should be able to deliver 45mA at ~3.5V.
It also allows rather fast measurement of voltage and current…
(2,124 Views)
