Barcode scanner key focus
Highlighted
Hi All
I have doubt in setting the key focus to the string.
Once i started the program, message pops up to the user.once the user clicked OK button the cursor have to come to string. I have attached my VI.pls give me some guidance
(1,226 Views)
Highlighted
Hi Veeru,
do you really need the PopUp every loop iteration? I made some changes in your vi, maybe it helps.
You should define an  event case for every Control you want to work with.
Mike
(1,211 Views)
Highlighted
Thanks Mike
I tried this example, but still i have same problem(cursor doesnt come to string box).
(1,199 Views)
Highlighted
Having a sepate popup when the bar code scan is itself a popup seems a bit silly.
(1,190 Views)
