Bar plot with gridlines visible over plot?
Highlighted
I have a bar plot and I was wondering if there is anyway to have the grid in the foreground and the actual plot in the back such that the squares are visible throughout the graph?
(1,340 Views)
Highlighted
To my knowledge there is currently no way to move the grid of a graph to the foreground, putting it above the actual plot. I will suggest to R&D that they include this feature in a future version of LabVIEW.
Please let me know if you need anything else. Have a pleasant day.
Sincerely,
Darren N.
NI Applications Engineer
DNatt, NI
(1,340 Views)
Highlighted
HI,
Would there perhaps be a workaround? Such that I could see the chart in squares as opposed to just the bar lines in a bar graph?
(1,340 Views)
I do not know of a workaround for this...the only thing I can think of is that you use a bar plot that is not filled, so that you only get the outlines of the bars, and thus can see the grid lines behind the bars.
I hope that suggestion helps. Good luck with your application, and have a pleasant day.
Sincerely,
Darren N.
DNatt, NI
(1,340 Views)
Highlighted
> bars.
This is probably the easiest, but another approach is to make an additional
couple plots that make up the grid. If using an XY graph, the grid is just
a data set that goes (X, Y0), (x, Ymax), (X+dX, Ymax), (X+dX, Y0), ...
You can generate the grid once in a loop and just append it to your data any
time you like.
Greg McKaskle
(1,340 Views)
