07-26-2015 10:34 PM
Hello All,
I want to calculate bandlimited A weighted rms noise. I am able to calculate the rms noise of analog signal without any bandwidth limitation. Find the attached vi for the details. I want to limit the bandwidth to some known values ( Say 20Hz to 20KHz) and then calculate the rms noise.
Please advice.
Thanks & Regards,
Siva
Solved! Go to Solution.
07-27-2015 01:13 PM
Siva,
What is the problem you are having?
I do not have the Sound and Vibration Toolkit but when I substitute a filter from the Signal Processing palette, I get changes in bandwidth and in the rms calculation. The RMS.vi from the Mathematics >> Probability & Statistics palette produces the same value as the Statistics VI you are using. The Basic Averaged DC-RMS.vi from Signal Processing >> Waveform Measurements palette produces values about 3 orders of magnitude smaller.
Lynn
07-28-2015 11:48 PM
Hi Lynn,
Thank you for sharing the detail. In Sound and Vibration Toolkit also , I see some audio filters. I can use and calculate the bandlimited noise.
Thanks once again for quick support.
Siva
