03-18-2021 05:42 AM - edited 03-18-2021 05:48 AM
HI,
I'm Using Ballard MIL 1553B
Model: 222-550-000
I need to create and configure a RT (RT address:2, sub address:1,word count:32) to send 32 bytes of data to external BC.
when I use examples (RT receive data example modified to send data/receive data) I'm not getting any kind of data in both in RX mode and TX mode also. If I configure it as BC instead of RT I can able to get a data (under MT mode).
I need a help to create and configure the RT as like as above mentioned
03-18-2021 06:01 AM
03-18-2021 07:03 AM
yeah, Im programming in LabVIEW 2015 using Ballard 1553 API
03-18-2021 08:09 AM
You might be seeing a bug I ran into last year. Astronics found an error in the DLLs. I don't know if that fix ever got released. They got me a beta version and it worked just fine.
Otherwise, I would need to see you code and configuration file (assuming you are using the XML configuration setup) to try to dig any more.
03-22-2021 12:10 AM
Yeah I'm using XML file to configure the RT. I had attached the image my VI, XML config. and VIs
03-22-2021 01:15 PM
But your code is writing 4 bytes to RT 5 subaddress 16. You need to update the rtAddress in the XML file to 2, the subAddress to 1 in the XML, and get RT index 2 from the array of RTs in the LabVIEW code.
03-22-2021 11:02 PM
Yes, I did that
even though I can't able to send or receive any data that's my problem. Im using multiple RT's In that this also a valid one.
This is the version on Ballard Driver I'm using for 1553
03-23-2021 07:51 AM
I have 2.12 installed and they had to send me an update for the BTICardLV dlls
03-23-2021 11:47 PM
Could you please share the driver or link to download that.
03-24-2021 05:52 AM
You can just go to Ballard's website, log in and download it here: https://www.ballardtech.com/support.aspx/myballard/. The OmniBus II is listed toward the bottom of the page.
