Bad conversion of Hostname to IP.
@fabioalmeidaa wrote:
I mean LAN when i use a laptop in my home network to access, and remote when I use a machine from a different location.
You're trying to do name look ups for systems that most likely don't have their names registered outside of your local network. In order for DNS to work properly your systems have to register their name with a DNS server. Local names are almost never advertised to the internet as a whole. In addition, your network will have a different IP address on the internet then it will on your local LAN even if the name was registered. Most home networks don't even have a fixed (static) IP address and use NAT (single IP address to the outside world).
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 17
(1,135 Views)
That's why I recommended creating his own filter.
If they always have the convention nnn-nnn-nnn-nnn.somename.com.br then why not filter the front ip-ish portion and create the IP address..
Ex
189-99-29-228.user.vivozap.com.br
In that case, filter out from the first period and you get
189-99-29-228 then replace the hyphens by periods and you get
189.99.29.228
and use that as the IP address..
Message 12 of 17
(1,124 Views)
Thank you guys, I guess that filter is my best option. I will look for some examples of string search and conversion.
Really appreciate your help!
Message 13 of 17
(1,121 Views)
Ex
189.99.29.228
This still may not resolve his issues accessing the device remotely. If the 189.99.29.228 address is the local address there is a very good chance that will not be th eaddress to access it from outside (remotely) the network. In addition, there is also the possibility of firewall settings coming into play.
Mark Yedinak
LabVIEW Champion
Message 14 of 17
(1,116 Views)
Agreed...
If the network is outside the local one, then it is not-likely he will be able to get that convention.  So you are right.  But that is why I mentionned "If they always have the convention nnn-nnn-nnn-nnn.somename.com.br"
Message 15 of 17
(1,112 Views)
Even if they use that convention it is unlikely it will work for both inside and outside access since the addresses are most certainly going to be different as I explained earlier. The filter willl most likely only work on one side or the other and not both.
Mark Yedinak
LabVIEW Champion
Message 16 of 17
(1,107 Views)
I think we're saying the same thing.  Maybe I should not have suggested a filter at all..  And resolve the root cause.
Message 17 of 17
(1,102 Views)
