05-10-2019 03:37 PM
05-10-2019 03:55 PM
I try to stick with VIPM 2014 SP2, that seems to be an old enough version that still supports most VIPM users. I've had trouble trying to install old versions of VIPM in the past as well, I agree that it's not straightforward. I think the LabVIEW 2015 installer includes an installer for VIPM 2014 SP2.
Good luck!
05-10-2019 03:59 PM
Up until very recently we were building all of our DCAF packages in LabVIEW 2014 SP1 with VIPM 2014 (some packages are still on this version). At some point we started using LabVIEW 2015 SP1 but stayed with VIPM 2014 which works but, like you said, you have to have an installation for VIPM 2014.
I have installed these built packages on computers with LabVIEW 2018 with the latest version of VIPM and haven't run into any versioning issues yet.
05-10-2019 04:12 PM
I have limited experience building VIPM Packages, but my assumptions were always as follows:
As I hinted above, I haven't tested these assumptions, but have noticed when I use OpenG with a newly-installed LabVIEW Version and save code in the new Version, it also updates the OpenG versions I referenced, suggesting it is re-compiling them for the current Version, so one Version of VIPM can install "older" Packages. I'm assuming that the Package Repositories don't all get updated (and Version-specific Repositories created) every year.
Would be interested in learning more about how VIPM and Packages (mine and others) and whether I should use the "oldest-practical" version of LabVIEW. [Since I'm a Channel Wire Enthusiast, that would probably be LabVIEW 2016 ...].
05-13-2019 09:54 AM
Thanks for all the responses! Right now, this issue is not super urgent and it helps to know that I'm not the only one with this problem.
