[BUG] Unable to change single numeric constant to array on block diagram
I was working on a VI to support some legacy C code... I attempted to change a single numeric constant into an array and it failed.  LabVIEW will flash an array icon for a few ms and then it will instantly go back to a single constant.
Steps to replicate:
  1. Create a new VI
  2. Open block diagram
  3. Place a new numeric constant (dbl) on diagram
  4. Right click -> representation -> single (sgl)
  5. Right click -> change to array
Tested:
LabVIEW 2016 v16.0f2 (32 bit) on Windows 10 64bit,
LabVIEW 2017 v17.0 (32 bit) on Windows 10 64 bit
LabVIEW 2016 v16.0f2 (32 bit) on Windows 7 64 bit
(3,470 Views)
Steps to replicate:
  1. Create a new VI
Tested:
Same problem on my machine
       LabVIEW 2017 v17.0 (32 bit) on Windows 7 64 bit
The reverse is also a bug. If you have a SGL array constant, you can't "Change to Element"
(3,452 Views)
@BowenM wrote:
  1. Create a new VI
Comments:
  • If you leave it as a Dbl, it works.
  • If you change it to a Sgl, then "Change to Indicator" or "Change to Control", then "Change to Array", it works.
  • If you really want an Array of Constants, you just need to do one more "Change to Constant".
Tested in LabVIEW 2016, 32-bit.  I'm not sure why Dbl works immediately and Sgl requires extra steps.  I tested several, but not all, Integer representations, and they worked.  Extended does not work.  Clusters seems to work (the Error Constant was my test example).
(3,446 Views)
@Bob_Schor wrote:
@BowenM wrote:
  1. Create a new VI
Comments:
Those are my observations as well.
Bill
CLD
(Mid-Level minion.)
(3,428 Views)
This right click menu item is actually a plugin so you can see where the error is coming from in Change Constant To Array Or Element.llb\Execute Change Constant To Array Or Element.Load Dig Num Config.vi. The VI is upset with the Display Format being entered in this specific cast [9 13] although I can't recreate the same problem by just feeding those inputs manually to the same BD items. The error produced by that property node causes the transaction to fail but this error happens after the array-scalar swap which is why you see the blinking behavior.
(3,386 Views)
