03-21-2014 10:03 PM
Before conversion:
After conversion:
If I then select the 2nd loop and hide its subdiagram label, the 'N' terminal moves up, ABOVE the loop (No snippet, because the 'N' simply disappears from the snippet).
There's no way to fix it, except to remove the loop and make a new one.
Solved! Go to Solution.
03-22-2014 05:31 PM - edited 03-22-2014 05:35 PM
I opened it in LV 13 and saved in LV 12. Opened it in LV 12 (and 13) and it worked fine.
LV 12 = 12.0.1f5
LV 13 = 13.0.1
Misread the post. Let me continue the experiment.
Okay after hiding the subdiagram label, it still seems to work correctly.
03-22-2014 05:53 PM
Sorry for not being clear before. My original snippets show:
This is what the code looks like AFTER I hide the subdiagram label in the converted code:
This happens regardless of whether I open the converted VI in LV2012 SP1 or LV2013.
Here are the details of my computer with LV2013:
Perhaps it was fixed in LV2013 SP1? (I don't have that version yet)
03-22-2014 05:55 PM
408914 | Using save for previous on a for loop containing a subdiagram label in LabVIEW 2013 causes the loop N terminal to appear on top of the subdiagram label |
03-22-2014 08:11 PM
Gave you a kudo because you're the one that figured it out. 😉
03-22-2014 09:15 PM
