BER of wireless modulation with USRP
Hi there
I have a trouble in measuring the BER of BPSK with 2 USRPs, one for Tx, and the other for Rx.  The trouble is that the results are different from the simulation.
The VIs are included in the "Digital Wireless Communication: Physical Layer Exploration Lab using the NI USRP".
 Attached are screen shots of signal consteration of both simulation and experiment with USRP.
I would appreciate any comments on the matter.
modulation   type BPSK
packet length   (bits) 1000
# of   Iterations 1000
filter   parameter 1
noise power   (dB) 0, -6
tx_hw params.ctl
device IP   Address
active antennae TX1
carrier   frequency 915M
Gain 0
Generation   mode continuous
rx_hw params.ctl
device IP   Address
active antennae RX2
Gain 0
(3,739 Views)
dear sir, Did you solve your problem? Because I am doing the almost same problem.  Thanks.
(2,845 Views)
can you share your vi files for simulation and the one which you attach here.
(2,742 Views)
