07-17-2025 11:23 PM
Hello community,
I'm currently working on a conditioning amplifier testing, I'm using the Bruel & Kjaer Nexus 2690 Amplifier for the measurement and testing. I was able to use the nexus drivers provided by the B&K, but I'm encountering an issue with the "Disconnect Nexus" driver.
Since the connect driver works perfect and so other drivers provided, I can notice that the display on the Nexus amplifier is still showing "REMOTE" despite adding the disconnect driver at the end of the sequence on the block diagram.
I was hoping if any of yous had a similar experience like the one I mentioned above. Is there a workaround?
any help would be appreciated.
07-10-2026 02:23 AM
Hi Barath,
Typically you send your device back to "LOCAL" mode before disconnecting…
07-14-2026 04:21 AM
If you investigate signal conditioners, do you know the
Calibration of conditioning amplifiers for dynamic application : Guideline DKD-R 3-2
https://oar.ptb.de/files/download/681c525953218de84f08e7e8
