Avoiding Tortoise's .svn files to appear on the Labview palettes
I'm using TortoiseSVN for version control and when Labview loads the palettes, the .svn files are also loaded and they appear on the palettes. Is there a way to avoid this ?
Thanks in advance.
(2,096 Views)
Accepted by topic author uzoyabuzo
Three options:
  1. Put the line skipSVNFolders=true in your LabVIEW.ini file. I'm not sure if this will work.
  2. Configure TSVN to use an underscore instead of a period ("_svn"). This works but you can't do it in newer TSVN versions and it would require you to check out all your code again.
  3. Don't put the user.lib code in the repository. Instead, have the source elsewhere (and in the repository) and deploy the code to user.lib using VIPM.
___________________
Try to take over the world!
(2,090 Views)
I've tried the first method (skipSVNFolders=true) : this seams to work well.
Thanks.
(2,082 Views)
