Avoid screen saver unwanted pressure
@billko wrote:
I would actually recommend "switch/latch when released".  This is the "usual" way a button works.
Command buttons should be set to Latch When Released.  Settings buttons should be Switch When Pressed.
And I am with Jeff here, just disable the screen saver and all of these problems go away.  And while you are mucking with these settings, make sure the computer never goes into sleep mode either (was just burned by this on Monday).
GCentral
Message 11 of 19
(782 Views)
@crossrulz
But we have sevaral devices in out factory that works 24/7 and for 24/7 the screens are turned off, i would not like them to be turned on!
Message 12 of 19
(775 Views)
And after all of my posts on windows power saving settings?  Tim, that earns you a post FULL of embarrassed emojis!
"Should be" isn't "Is" -Jay
Message 13 of 19
(763 Views)
@JÞB wrote:
@crossrulz wrote:
@billkoAnd while you are mucking with these settings, make sure the computer never goes into sleep mode either (was just burned by this on Monday).
I knew I was going to get crap from you by making that statement.  I had just formatted the computer, got in a hurry, and forgot to change the sleep settings.  But I did remember to disable the USB suspend option.  Just adding to the checklist of things to do to new computers...
GCentral
Message 14 of 19
(761 Views)
Not a CLA
But I can teach them
You can save, edit and import power profiles on windows.   Perhaps I-thingys too but, l don't play with Apples unless I'm juggling them.
Yes, I can juggle apples or magic 8-Balls
Message 15 of 19
(758 Views)
@JÞB wrote:
Not a CLA
You didn't teach me.  I learned from my own idiocy.
GCentral
Message 16 of 19
(756 Views)
@crossrulz wrote:
@JÞB wrote:
Not a CLA
Failed to listen......
My own idiocic mistakes should not be repeated.  Lol
Message 17 of 19
(753 Views)
@gepponline wrote:
@crossrulz
Turn them back on! The monitor consumes 99% of its max energy just in standby.  The power to drive the LCD display is chump change
Message 18 of 19
(736 Views)
@JÞB
1% for billion of PC will save the world 🙂
Message 19 of 19
(725 Views)
