Averaging values in 2-D Array in a circular area
I'm trying to average temperature values in a 2-D array, rectangular coordinates, over a circular area.  Is there a sub-array function that works in polar coordinates, that I could utilize?  Any suggestions would be much appreciated.
Message 1 of 38
(8,018 Views)
In the Mathematics >> Numeric >> Complex palette there are conversion functions to convert to any other complex type.  Then you can use other functions that work with complex data in those types.
Message 2 of 38
(7,977 Views)
My professor found out a simple but crude solution,  by using a couple for loops to go through each point in the 2-d array and checking if the distance from the circle's center point is within a specified radius.
Message 3 of 38
(7,950 Views)
Is the array always the same size?
Easiest would be to create a "mask' array that is "1" in inside the circular area, and "0" outside. Now just multiply the mask with your array and then use "add array elements" on this result and on the mask array. divide the two numbers to get the average. No loops needed.
can you attach a VI containing some typical data?
Message Edited by altenbach on 07-02-2009 10:33 AM
Message 4 of 38
(7,941 Views)
Perhaps you should first take a square subarray (with the size of your circular region of interest) from your 2-D Array and than proceed with your profs idea or with Altenbachs idea. This could save some computing time by avoiding unnecessary comparisons or multiplications.
Jörn
Message 5 of 38
(7,929 Views)
http://forums.ni.com/ni/board/message?board.id=170&message.id=384632&query.id=227790#M384632
The solution I came up with is discussed near the bottom of the page.
Tim Elsey
Certified LabVIEW Architect
Message 6 of 38
(7,926 Views)
Here's a quick example of what I had in mind (LabVIEW 8.5).
You can move the circle with the cursor and change the radius. See if it makes sense. 😉
(It's pretty crude, but shows the main idea. Many improvements are possible)
Message Edited by altenbach on 07-02-2009 03:55 PM
Message 7 of 38
(7,913 Views)
this should do it
"Should be" isn't "Is" -Jay
Message 8 of 38
(7,902 Views)
Jeff, I think two loops are enough. 🙂
We also should accumulate the sum in a scalar, e.g. as follows, no need to built an array:
It's less pretty compared to my previous post, because we are flying blind, but operated pretty much "in place". This is good for a "code only" solution, where we don't need visual feedback.
Or we could only graph the "counted" points as follows:
Message Edited by altenbach on 07-02-2009 09:14 PM
Message 9 of 38
(7,888 Views)
Seems we can only attach 3 items. Here's the code for the last option (LabVIEW 8.5.1).
Message 10 of 38
(7,883 Views)
