09-28-2020 05:14 PM
Hi everyone,
I want to preface with the fact that I have no Labview experience and have been trying to teach myself most of it for the last while.
What I'm trying to accomplish is the following. I have a Hamamatsu Orca Flash 4 V3 camera, which comes with a video capture library for LabView. I am trying to perform the following calculation for live image processing: <I^2> / <I>^2, where I denotes the intensity at each pixel of the image generated by the camera, and <> denotes the time average over N frames. So ultimately, I would like to display the raw live stream from the camera, and along side it, display the images generated by this averaging and normalization as the live stream acquires more images. I use the Hamamatsu video capture library to initialize and grab images from the camera, and use the IMAQ pallete to visualize the images. I have attached a VI and a screen shot of the VI (as you may not have some packages). Any help would be greatly appreciated.
09-29-2020 05:54 AM
From the manual:
Refer to the following for examples that use this VI.
Then use imaq_muldiv To multiply it with itself (^2)
10-01-2020 02:09 PM
Hi!
Thank you so much for the reply. I was able to use some of the samples provided by Hamamatsu and use a buffer and average the images. However, now I'm having an issue with the math. When I square the images by using the IMAQ Multiply function, I think I'm overflowing the image, and i end up with a completely white image. Do you think there's a way around it? I tried using IMage2Array, squaring it with numeric square, and then converting back, but I still get a white image and the processing gets much slower. I've attached my HTML file for the code, and a VI.
10-02-2020 03:28 AM
You probably can make the dest image a float type image
10-02-2020 12:11 PM
Could you explain how I would do that in my block diagram?
10-02-2020 12:22 PM
Where you create images for squares, Average of squares, Final Image, etc. with IMAQ Create.vi, change the enum Grayscale (U16) to Grayscale (SGL).
I don't have IMAQ installed right now, so I hope it's clear and actually works.
10-02-2020 12:29 PM
Okay! I just tried that where I switched all my images to SGL, but now my images are all black (nan).
10-02-2020 01:11 PM
It's probably time to wire some output errors, so you get feedback from those functions.
Probably the multiply doesn't allow two Grayscale (U16) image sources to be put in a Grayscale (SGL) image.
You might have to convert the Grayscale (U16) images first, but I couldn't find the function for that from just the manual.
