Oups... about the Properties & methods there or not there, I made a mistake.
All is good, sorry.
PS/ But the other question is still not clear to me !
M
Matthieu Gaillet a écrit dans le message :
39472e08@newsgroups.ni.com...
> Hello,
> I'm wondering what's the use of the "automation open" ?
> I'm currently using ActiveX, in order to display a chart coming from the
> MSGRAPH 8.0 ActiveX. It seems to work properly, without using these
> automation open. I siply put a container and use the reference given by
this
> container to use the properties & methods of this object.
> Some examples found on the site do use this automation open, other do not
> Other problem : Using the MSGraph Activex, I encounter problems with the
> pr
operties & methods : some are there, some are not, following the help
file
> given with this activex. I mean that the properties & methods usable in
> labview are not the same of the which should be available following the
doc
> of the activex. I'm currently using lv 5.0.
> Last question : are there any NI guys there ? Simply asking.
> Matthieu Gaillet Matthieu.Gaillet@euronet.be
> Technicien R&D
> C.C.R.M
> Rue des Belles-Pierres 5
> 1421 Ophain
> http://users.skynet.be/ccrm
