Automated Word Report Printer from a Cluster filled with controls Vi
I am sharing this Vi that i made to solve a problem i had.
Basically this Vi will take what ever is inside a cluster  and print it to Word. you should have a Word template with Bookmarks to work. The bookmars name should be the same as the label of the control( i am explaining the function more in depth on the block diagram comments). This way you can make fancy word templates to print in the report your own values of your test.
express vis come limited in the number of inputs you can feed to a template. so this will make you life easier on printing a report. you just need to worry now about putting the values in the cluster.
You can find it here
CLAD, CTD
Message 1 of 1
(2,161 Views)
