11-23-2011 02:30 PM
Is it possible to change the units e.g mm to inch and have the scales of gauges change automatically to the maximum and minimum values defined for the gauges?
Kind Regards
Austin
11-24-2011 09:16 AM - edited 11-24-2011 09:18 AM
Hi Austin,
Yes, it is possible to automatically change the units you want the graph to be displayed in.We can do this using property nodes and case structures. I have produced a quick example to show you how this can be done. The example simply allows you to change units between meters and centimeters.
I hope this helps, but please do let me know if you need anymore help.
Many Thanks,
11-24-2011 10:11 AM
Hello Aaron,
Can you save this for version 2010 please. I dont have 2011
11-24-2011 11:00 AM - edited 11-24-2011 11:01 AM
Hi Austin,
Please find attached the code for LabVIEW 2010.
Many Thanks,
11-24-2011 11:10 AM
Sorry please find the attached using moden controls.
Many Thanks,
