02-16-2017 04:18 AM
Hi All,
Currently I'm trying to make an installer for our system (developed in LabView+TestStand). Apart from LV and TS files the software usses a massive amount of other files; in order to deploy them easily on the target machine I want to include all of them, together with their hierarchy, as auto-populating folders. Seem fine.
Then a prepare the installer, we need three folders:
C:\Foo - this is the main installer for our stuff (TS Sequence, main lvlibp, some config files) and this one is the default instalation path.
C:\Foo_tools - this is an massive folder with around 16k files and I-don't-even-want-to-know how many folders in the hierarchy.
C:\Foo_legacy - this is some additional tools folder, that we need due to "historical reasons". Fairly simple structure, 5 files 2 folders.
So my problem is that I have an auto-populating folder for Foo_tools (or actually three folders: Foo_tools/something1, Foo_tools/something2 and Foo_tools/something3) that I just want to put there. But I can't, as it seems that you can put the auto-populating folders only into the default folder, not anywhere you want. What should I do? I see two possible ways:
If you have any better ideas I would be glad. Maybe there is some other possibility that I have overlooked or some setting in LV Installer Builder that I'm unaware of.
02-16-2017 09:28 AM
Honestly i dislike autopopulating folders.
I recommend you to use the TS Deployment Utility as i consider it superior to LV AppBuilder regarding building installers. It enables you to include folders into the build process.
02-17-2017 12:53 AM
Thank you Norbert for that suggestion but I prefer not to use any external software for that, as if I do it has to be used by all people in the team, and this makes things a bit more complicated. I'll stick with the LV AppBuilder.
For now I'm just using zip files with the whole hierarchy that I unzip after the installation. It works but is far from beaing 'neat' for my taste.
02-17-2017 05:50 AM
Okay, I've started with a different approach - as the lvproj is an XML file it should be possible to edit it manually. For now I'm able to read the whole thing and I see the folder tree, that I've configured (manually ) in the Installer.
The only problem that I see is that i don't know how to henerate the tags for the folders - they look like so: {C63B6F86-C439-4240-9AAE-EC6A9DDD0A29} - any ideas how it is generated?
