Hi all
As one might know there are different versions of LV in use and not everyone uses the newest version.
Often there are attachments in some topics I'd like to look at, but in the end I can not
😞 because of the version (I use LV7.0, which is not that old). I'm sure that there are others with the same problem.
I would find it great, if we all could decide to attach vis in one version. If one still uses an older version of LV than the version determined to attach vis, he could attach vis without any problem. The other way round - ok, here the problem remains - it must be explicitly declared that he uses the vi in an other verion.
Maybe it could also be possible (as in the LAVA forums) to add an indicator about the version in use. (Yes, maybe NI could improve user-information ;))
What is your opinion?
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
