Async VI works during the IDE but no longer functional after building it to exe.
Greetings everyone!
I have the below async (sub) vi that works during the development but no longer functional after building it to exe.
I hope that someone can point me to the right direction - as this application must work. Thanks in advanced!!
______________
KowdTek
LabVIEW 2009
One Step At A Time, Maybe Two...
(3,556 Views)
Accepted by topic author KowdTek
Read Why Do I Get Error 7 When Running My Executable Built in LabVIEW Versions 2009 and Later?
Actually, that is more about the change in file layout in a newer executable vs. old.  But the key point in there is the name of the executable becomes a part of the VI file path.
Also, did you remember to include that VI has part of the build?  I'm trying to find a few other links that explain this.
Here is one.  http://digital.ni.com/public.nsf/allkb/FD7DE8BC8FFC256C862565F4006BE363
(3,551 Views)
Did you include it in the build, in the Always Include subsection?
The other problem is you have a hardwired path in it. Use something like this instead.
mcduff
(3,548 Views)
Hi!
I have missed to include the vi as part of the build.
Thank you very much!!
______________
KowdTek
LabVIEW 2009
(3,516 Views)
Hello mcduff!
Thanks for pointing the hardwired path, adding the subvi as part of the build and changing the reference fixes the issue..
Thanks a lot..
______________
KowdTek
LabVIEW 2009
(3,510 Views)
