Assistance with VI build
Great afternoon LabView Team,
I need assistance with a VI attached, I want to add a GUI to represent the change from one valve to the next. I provided a screenshot of an example of style for GUI called Hamilton. Also attached is the VI that was created by your team a few months back. The VI works with hardware just want a better GUI that shows change, similar to attachment, I don't know how to call the function when the valve is changed. Please compare and let me know how I can build VI to call valve position similar to Hamilton set up.
(953 Views)
You did not attach any VI. (A picture of a diagram is NOT a VI and not useful!)
You can du your GUI with a picture indicator ( or an image ring if there are only a limited number of possibilities).
(934 Views)
Please refer to VI attached to post.
(931 Views)
How do I call or build picture indicator?
(925 Views)
On the front panel:
Using the 2D Picture Control
On the diagram:
https://zone.ni.com/reference/en-XX/help/371361R-01/lvpict/picture_vis/
Have a look at the various examples in the example finder.
(911 Views)
Thank you, would you happen to have any video links?
(907 Views)
