Assignment of 2 signals with different scaling on a curve diagram, LV 6.1
Hi there,
how is it possible to assign 2 signals with different Y-scaling on the Y-axis in curve digram?
I´m using for this old projekt LV6.1
In LV7.1 it is possible over the properties of the graph -> Plot-> Y-axis.
Need help!
(2,515 Views)
I don't think this is possible in LV6.1. Probably the best thing you can do is work around it by dividing one dataset by a suitable number and then making the scale on the right side yourself. This is easy if you have a fixed Y scaling. If you have automatic Y scaling, this can be "followed" automatically by calculating from the YScale.Increment property, moving string indicators around programatically etc., but it will be a lot of work.
Martin
(2,510 Views)
You have the ability to create a different scale in 6.1. Just right click the axis your wnat to duplicatre and select Duplicate Scale. You can then select the scale you just created and do a Swap Sides if you wish. You assign which plot goes to which scale by clicking the plot legend and then either the x or y scale (depending on which one you duplicated). When you pick the axis, both scales should be available for selection.
(2,504 Views)
Yes, thanks alot.
I´ve solved it already by right click on the axis legend.
Ugly problem with easy solution....!
Thanx!
(2,498 Views)
Embarrassing... I should have known that... I'll just console myself that being corrected by Dennis is less embarrassing 🙂
(2,490 Views)
