Assembling the voltage sensor and tamura (current sensor) with a myRio microcontroller
good afternoon I am fitri. I got a project from campus to make a Battery Management System. The sensor used are the Tamura L01Z100S05 sensor and the voltage sensor for the micro using myRio. I want to ask about how to assemble the two sensors to connect with the myRio micro ?? thankyou
(808 Views)
Hi fitri,
Did you read the datasheets for all components in your setup?
Then you should know which pin of the current sensor needs to be connected to which pin of the myRIO!
@fit1177 wrote:
I got a project from campus…
Don't you learn to read books and datasheets in highschool anymore?
(779 Views)
