As a closing session imaq correctly
Hello everyone I have a question, I have implemented a basic application of vision, with a "while" and "Stacked Sequence" continuously reading achievement video of a webcam image. The problem arises when I close the session. Sometimes everything works perfect, in other labview an error occurs and closes completely.
Thanks.
(4,352 Views)
Hi
What erro you are reciving?
May you post your block diagram?
Abel
Abel Souza
Engenheiro Eletrônico
LabVIEW User since 8.5
(4,310 Views)
Which version of LabVIEW you are using and what is the Web cam... I have encountered the same problem when i was working. Post the block diagram you made that may let us to help you better.
Smiley Wink
(4,297 Views)
