Array of clusters and in the cluster is a bar meter, how can I change the color individually?
Array of clusters and in the cluster is a bar meter, how can I change the color of the bar meter individually for each element of the array?  I have just figured out that you can't change properties of one element of the array without all elements changing.  For the scaling I had to make numeric indicators for each tick of the scale so that each bar meter in the clustered array would have individual scales.  I also had to do some math to scale each barmeter to display correct proportions from 0 to 100%.  Now I'm stumped on the color of the bar meter.  Basically, if the value goes over a setpoint, the bar meter needs to turn red.  It has to be in an array to be infinitely scalable.
Matt
(2,826 Views)
You can't do that-
without a little trick.
You could consider laying a custom color box over the bar graph in the cluster you can set the color based on the value of the bar graph or even make a "Pseudo"- bar graph using a series of color boxes stacked to look lie a bar and changing values of the Color boxs from empty to full to red.
Here is an example to demonstrate
"Should be" isn't "Is" -Jay
(2,823 Views)
Accepted by topic author Mattjk
And yet anothr approach...
right-click the bar >>> Fill Options >>> Fill to maximum.
Color the fill the same color as the background color then make the background color transparent.
Drop a color box BEHIND the bar and size correctly.
It has this weird 3D background with flat bar, but what the hey, its close. If its important a customized color box.
Ben
(2,806 Views)
This is a good idea Ben, Thanks.
(2,789 Views)
