Array of (T0, Y1, Y2, Y3) clusters (with Blanks) to Graph
I have an array of clusters each cluster has a timestamp (Xn) and an array of dbls (Yn,1; Yn,2;Yn,w...)
How can I change this arrangement into W clusters of Graphs with (Xn,Yn) arrays while not adding 0's to empty arrays:
Example:
Fortunatly, it can be assumed that the first value in the array will always go to the first graph, the second to the second ect.
(3,410 Views)
Update:
Got it! However, it's a bit slow. Can anyone think of a better way?
(3,386 Views)
Hi ATE,
why do people always use this "Insert into Array" function when all they want to achieve is to append elements to an array? Why not use BuildArray instead?
This way you can eliminate the ArraySize function and the comparison before the case structure…
You can also determine the largest array size in your input data. Use this information to initialize the output array with the correct number of "plots"…
(3,381 Views)
@GerdW wrote:
Hi ATE,
Hey Gerd,
I do use BuildArray to add the X and Y values, into "plot N." After that, I'm using the "Replace element in array" to override the previous array state.
Also, How would I go about determining the largest size in the input data?
(3,371 Views)
Accepted by topic author ATE-EGNE
See if this works for you. No guarantees.. 😄
Seems to give the same result.... (but please test on other data)
Note: since the inner array cannot be larger than the outer input array, you could just use that, eliminating the first loop.
(3,366 Views)
