Array 2D in FPGA. Error: Max number of dimensions exceeded for target.
Good morning.
I have a fpga-project with a .vi in fpga. In this .vi i have a matriz with a 4 row x 2 columns. When I want to execute this .vi, i obtein an error: Max number of dimensions exceeded for target.
I know that the FPGA not supported arrays that they are bigger than 1D, because I have already read other discussions, but,
SOMEONE KNOWS HOW CAN I IMPLEMENTATE MY MATRIX IN MY FPGA?
Thanks so much.
(3,176 Views)
Hi cristina,
LV-FPGA only accepts 1D arrays of fixed size. Point.
No need to cry.
Reshape your "matrix" to a 1D array, then process the elements as needed.
(3,158 Views)
Do you know how can i read the array 1D in fpga in host? I have used the read/write control buy the array doesn't appear at options.
Thanks.
(3,136 Views)
I'm using arrays of 1D and when i compiled the .vi, labview shows me this errors:
The FPGA Module does not support variable-sized arrays on the front panel of the top-level VI.
(3,129 Views)
Hi cristina,
as I said before:
LV-FPGA only supports 1D arrays of fixed size!
(Right-click those arrays to set a (reasonable) size limit!)
(3,123 Views)
