Are we really 'helping' students?
There are some great, experienced and very helpful posters on here. It concerns me a little however that students are regularly coming on here with projects and rather than a nudge in the right direction, they're given the whole answer lock, stock and barrel, usually with running code.
Do you think this helps them? I've no doubt it helps them pass 'the test' with flying colours, but what do they learn in the long run? Or is that none of our concern?
Message 1 of 11
(5,699 Views)
I won't speak for everyone but,....
As a community I believe we generally do identify the "Do my homework for me threads" fairly consistantly and do a pretty good job of encouraging those students to study and do thier own homework while still offering support for any skill gaps or flaws in their understanding of LabVIEW.
Am I 100% sure I've never done a student's homework for them?   No, the number of responses I've posted almost garuntees I've let one or two "cheat off my paper."  But, I try to keep them honest .Smiley Wink
"Should be" isn't "Is" -Jay
Message 2 of 11
(5,693 Views)
Don't worry. It's job security for the rest of us. They won't knw to do anything when they get out of college. Besides, the ones posting homework questions will most likely be the ones that drop out of engineering and enroll in business school.
Message 3 of 11
(5,674 Views)
I'm sure I've been guilty of giving answers to those who are too lazy to do their own homework.  I try really hard not to though.  I will usually give an example to show a concept that will get them 50% the way there.  I find a lot of students who are legitamitly trying are stuck on one or two concepts.  And once they figure those out, they are good to go.
First I want them to try to think through the problem.  Many of them won't even do that.  And I refuse to help those people.  There was one time I got so annoyed with somebody that I gave them exactly what they asked for, except I purposfully put in 3 or 4 major (but somewhat hidden) bugs.
Message 4 of 11
(5,598 Views)
I agree, most here don't just spit out working code to questions likely coming from students.
I, for one (as many here have surely noticed) do not hand up a slice of code at the first question of a likely student (few posts, new forum member, does not show what s/he has tried already, only posts to ask questions), and/or if I've seen a poster asking really basic questions before and the new question seems to be just a baby step further on their project. I'm also sure I seem quite terse in some of my answers, since I regularly just point to web tutorials for those whose questions imply that they are truly clueless. Again, as others, I'll often just try to quickly point students in the right direction. But, as crossrulz says, some are just stuck on a minor concept (been there, done that, I'm there now on a couple of things), and pulling them through that (sometimes kicking and screaming) can be satfisfying to both of us. If someone shows effort in solving a problem, I'll go at least halfway with them to do it. Hopefully, I'll even be right, and if I'm not quite there, I get corrected by the more knowledgable here and learn something myself. Smiley Embarassed
That said, there are a few here that will immediately post a solution for a poster's homework for them, knowingly. I don't think they're helping these students a bit, but I have learned, from being a college teacher for 26 years, that there are some cultures which actually condone or even promote this (even cheating on tests) for whatever reason, and neither the student nor his/her parents can see where I have a problem with it. As jmountney said, the people who raise these questions just looking for copy-and-paste answers to hand in are going to Darwinize themselves from the "gene pool" quickly when they are on their own in an exam, certification test, or job interview. Not the best situation, but such is life.
Cameron
To err is human, but to really foul it up requires a computer.
The optimist believes we are in the best of all possible worlds - the pessimist fears this is true.
Profanity is the one language all programmers know best.
An expert is someone who has made all the possible mistakes.
To learn something about LabVIEW at no extra cost, work the online LabVIEW tutorial(s):
LabVIEW Unit 1 - Getting Started</ a>
Learn to Use LabVIEW with MyDAQ</ a>
Message 5 of 11
(5,568 Views)
Well, giving a solution, especially a surpisingly simple one is not necessarily a bad idea, especially after the student has struggled for a while. We can assume that the teacher also reads these forums and will know what kind of "solutions" are out there.
Maybe we should be more strict to always fill the documentation. A VI description that contains our name and date and a link to the original forum discussion would probably not be found by the beginning student, but can help the teacher evaluate the originality of the solution turned in by the student. 😄
In any case, the student needs to be prepared to fully explain the reason for every single diagram element of whatever he turns in, if he cannot, he should fail. Learning from example is a valid approach, why else would we have the example finder???
LabVIEW is hard, especially for the beginner, because there are often misconceptions about dataflow. Sometimes it is just the simple mechanics of wiring. For example they might accidentally turn off auto-tool and suddenly nothing seems to work anymore. 😮
A clean solution can give that little push ("Aha!!! moment"), after which things start rolling along just fine. We've seen it all here: A great student, that, after seeing a clean solution, takes it far and beyond, and the bad student who keeps struggling for days chewing on the simplest of concepts without getting anywhere. Not everybody can be a LabVIEW programmer.
If I would be teaching a LabVIEW class, I am pretty sure I could grade a student correctly, even if they turn in some stellar plagiarized homework. No cheating student can match programming style across all they submit and there will be a mix of diamonds and turds unless the student knows exactly what he/she is doing.
Most likely there will also be a final test where the forum is not available. A good introductury course should end in a CLAD-like quiz about all covered topics.
I believe our main mission is to get receptive students hooked on LabVIEW. We don't really care what will happen with the rest. They might pass the course, but will never touch LabVIEW again, so who really cares.
Prospective employers should focus exclusively on official NI certification anyway. These are hard and cannot be faked!
Message 6 of 11
(5,545 Views)
Thanks for the feedback, guys. Interesting to see the range of views on this one- all the way up to SABOTAGE! I can understand the frustration. Smiley LOL
I guess you can't make someone learn who doesn't want to learn. The students who put the effort in will gain even if we give them the whole enchilada, those who don't will learn precisely nothing either way.
Message 7 of 11
(5,525 Views)
Speaking from my own personal introduction to LabVIEW, eighteen years ago I contracted a LabVIEW integration company in Atlanta to write a couple of programs.  One of them controlled a bank of digital inputs and outputs, and the other read the serial protocol of a Banner beam array, and converted it into output suitable for display on a graph chart.  Up until that point, my only exposure to programing languages had been Pascal, C, and Basic.  I had not been able to wrap my head around the LabVIEW paradigm until I got that code in my hands.
From those two examples, sprung my passion for LabVIEW, and a lifetime career.
At that time, my job responsibility was not to write LabVIEW code for the devices, but to get them working with some kind of GUI, for troubleshooting, so to have someone elses work to show was perfectly O.K.  These students that come onto the forums looking for someone to spoon feed them answers will only benefit from code examples if they take the time to understand why and how the code works.  I don't think we should be providing complete solutions, but whatever is provided should demonstrate technique.
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
Message 8 of 11
(5,501 Views)
@jmountney wrote:
...Besides, the ones posting homework questions will most likely be the ones that drop out of engineering and enroll in business school.
And once they graduate, we'll be working for them again 🙂
S G
Certified LabVIEW Architect, Certified TestStand Architect, Certified Professional Instructor
Message 9 of 11
(5,471 Views)
"And once they graduate, we'll be working for them again :smileyhappy:"
Yup, at which point they will put the skills they learned here to work- that being the skill of claiming credit for out work. Smiley Indifferent
Message 10 of 11
(5,426 Views)
