Hi everyone,
The attached VI shows the endmembers in case structure form of a relatively simple task I need to perform. It takes a bank of 6 digital outputs and toggles between true and false logic. Between the endmembers, I need to change the logic on some ports sequentially and after time delays. For instance, changing the case from true false, I need to change line 2 from false to true 2 seconds before I change lines 4 and 5 to true. I want the user to see only one button to toggle between states, and I want the states to be discrete and not continuously changing.
Are sequence structures the best way to do this? If I put those into the case structure, won't it re-iterate the sequence over and over? Or do I need a case structure initialized with shift registers so that it stops after one interation until the next time the user toggles the control?
Thanks for any help on this,
Brad
