Are registry locations all that is needed to use DSC module?
Hi All,
New to Labview and our technical staff is pretty busy so I am trying to solve our issue but I am not sure that I have all the necessary information to do so. The NI rep told us that DSC was as simple as point and click to setup but I am not to point!!We have a BioFlo110 bioreactor that can be supervised via modbus server. I did the tutorial on How to create a modbus I/O server but when I need to tell the DSC to look for my values I am not sure how to do it. This is the information that came with the equipment concerning modbus communication:
ModBus Communications Protocol
All BioFlo110 parameters are represented by Register assignments (see Register Map
in Section 13.3.1 below).
The BioFlo 110 implements Modbus functions 03, 06 and 16 decimal.
All registers are transmitted high byte first then low byte (standard Modbus format).
All floating point values are stored in two-Register pairs, with the higher half in the
first (even) Register and the lower half in the second (odd) Register. Therefore,
floating point values are transmitted as four bytes, starting with the highest and ending
with the lowest.
Control Type Value
OFF = 0X00
Auto = 0X01
Manual = 0X02
ON/OFF = 0X03
P-DB* = 0X04
Total = 0X0B
3.3.1 Register Map
Loop number: 0 1 2 … 31 Formula
Parameters Decimal Address
1-Curr_val: 0 2 4 … 62 0 + (N Loop * 2)
2-Setpoint:
64 66 68 … 126 64 + (N Loop * 2)
3-Control_out:
128 130 132 … 190 128 + (N Loop * 2)
4-Integral:
192 194 196 … 254 192 + (N Loop * 2)
5-Derivative:
256 258 260 … 318 256 + (N Loop * 2)
6-Raw_float:
320 322 324 … 382 320 + (N Loop * 2)
7-Cal_gain:
384 386 388 … 446 384 + (N Loop * 2)
Also, would there be a more specific tutorial on how to use the information provided to build the application?
Any suggestion would be greatly appreciated.
Thank you
Albert
(2,668 Views)
Hi Biotech014,
It seems like you are trying to create some bound variables. I believe the below link is what you may be looking for;
Hopefully this helps out!
Aashish M
CEO
TransferFi
www.transferfi.com
(2,639 Views)
