If you want to block the menus, choose VI Properties from the File Menu then choose Windows Appearance from the dropdown box. Click on the Customize button and you will find options to turn off pop-up menus and the menubar. You can also turn off a lot of other things (scroll bars are one I turn off regularly).
This should keep your user(s) out of the menus. Hope that this is what you are looking for.
Rob
