Arduino analog input
Highlighted
Accepted by Hatemaboud
@Hatemaboud wrote:
ok so now when I upload the LIFA_Base I get an error message says (( this chip is not supported))
LIFA has long since been deprecated and replaced by LINX
Here's a tutorial to get you going. Getting Started with LINX
In this tutorial we'll install LINX, setup a new LINX device and run our first example
Unfortunately, most readers of this Forum, including some real Experts, have not mastered the skill of being able to read the code that Posters fail to post. If we cannot see "what you did wrong", we are unable to tell you how to fix it. (Bob Schor 28 August 2018)
Message 11 of 15
(185 Views)
LINX can be quite a bit easier to use than LIFA ^
(You are currently using LIFA)
Message 12 of 15
(181 Views)
Thank you so much, now it Works.
but still have a small question; it takes few seconds to start reding the signal from the potentiometer at the begining then when it starts reading it continues well, is that normal or there is something wrong!?
Hatem
Message 13 of 15
(167 Views)
Thank you so much, now it Works, but still have a small question; it takes few seconds to start reding the signal from the potentiometer at the begining then when it starts reading it continues well, is that normal or there is something wrong!?
Hatem
Message 14 of 15
(165 Views)
It is normal that the setup of communication can take some time.
Message 15 of 15
(153 Views)
