03-13-2020 07:38 AM
Help required, if anybody knows how to loop this waveform continuously! I tried to make this waveform using arbitrary wave generator VI. I am able to make the waveform but cannot loop it continuously.
Help in any form will be appreciated. Thanks!
03-13-2020 07:59 AM
Hi inji,
You VI is huge and can be simplified like this:
Just output the waveform again. What is the problem?
03-13-2020 08:16 AM
What are you trying to loop this waveform on? A DAQ analog output? A function generator? Or are you just trying to repeat an operation in software? We need a lot more context for what you are trying to do with this waveform in order to actually help.
03-13-2020 08:20 AM
Thank you for replying.
I want to continuously loop the waveform. When the waveform ends, it should start again from the beginning, like all the inbuilt waveforms present in labview.
03-13-2020 08:28 AM
Hi inji,
No "inbuilt waveform" does "start again from the beginning"…
Create the waveform, then "play" it in a loop.
You still don't explain where you want to play/output the waveform!?
03-13-2020 08:34 AM - edited 03-13-2020 08:38 AM
Yes, I tried to loop it using a while loop 😐.
Sorry if I being lame. I want the waveform to repeat periodically. Also, what is the process to change the units of time.
I want to get the output of the waveform using a NI USB 6001.
Thanks again!😊
03-13-2020 09:20 AM - edited 03-13-2020 09:22 AM
@injimamul wrote:I want to get the output of the waveform using a NI USB 6001.
There's the key information I was looking for. Luckily for you, there is a DAQmx Write property called Regeneration Mode. Just set that to be "Allow Regeneration", write your waveform to the DAQmx task, and then start the task.
NOTE: This VI was based on having multiple channels in the task. Hence why Waveforms is an array. It will still work with a single (scaler) waveform.
03-13-2020 01:40 PM
Could you please share the VI file of this?
Thank you so much. I cannot believe of getting such great response in this short period of time.
Keep helping sir!
03-13-2020 07:54 PM
Save the PNG file to your desktop. Then drag that file into your block diagram. If you are using LabVIEW 2019, then you'll have the code!
03-13-2020 11:01 PM
Sorry, our institution has provided us with the 2013 version. This feature is not working in this version.
