11-13-2020 04:45 AM
wiebe@CARYA wrote:
@VinnyAstro wrote:
@GerdW wrote:
When you want to automate the LabVIEW IDE then you should use scripting…
Understood. I need to take some time to learn scripting 🙂
I'd recommend you learn VI Server first... Scripting gets complex fast.
I'll have a deeper look at it. Thanks for the suggestion.
11-13-2020 08:02 AM
@VinnyAstro wrote:
wiebe@CARYA wrote:Packed libraries are compiled, so you can have usable VIs, without distributing source code. It's a huge topic on it's own.
Yes, about that, I had other issues that I noticed here ...
I'm lucky that I can, for now, avoid them... I watch the discussions, and let other sort things out. I pick my battles 😊, and I have plenty others. Sorry...
11-13-2020 09:35 AM
haha no worries, I was just pointing out that using packed libraries doesn't necessarily solve the problem of code protection sadly.
11-13-2020 10:06 AM
I'm pretty sure packed libraries remove source code from a library.
It's basically a dll while keeping the VI API, so you can use the functions like normal VIs, but without diagram. Are you sure you tested packed libraries? Those are not regular libraries.
11-15-2020 08:28 PM
I have developed a LabVIEW addon that enables simple scripts to be run on multiple VIs, selected using a compound search and sort by individual properties. Both QuickDrop and VI Analyzer scripts are supported. Several sample scripts are available to get you going quickly. Setting the password on multiple VIs is a built-in feature. Free 30 day trial includes unlimited use.
11-16-2020 02:42 AM
They surely do, but not if you enable debugging, which I had to because some VIs won't execute otherwise... And still couldn't find why.
