Application cannot be built with class and interface in the same lvlib
Hello everyone,
I have experienced the following weird behaviour with LV2020:
If you have a class and an interface (the two are not related in any way) in the same lvlib and your application is using the class then the build fails with this message: LabVIEW: (Hex 0x696) You cannot inherit an interface from a class. Interfaces inherit only from other interfaces.
(1,322 Views)
Update:
This error is related to the "Remove unused members of project libraries" option in the build spec:
If turned off then the app builds just fine and it is the same if all included classes & interfaces are used in the application.
(1,308 Views)
@ImreSzebelledi  已写:
Update:
This behavior should be reported as a bug to NI. Uncheck "Remove unused memebers of project libraries" would cause some side effects when you're building a "real" application which is more complicated that this narrow-downed version. It should be fixed.
And a workaround is to build the .lvlib to a Packed Library(.lvlibp) first then direct call VI's from the packed library rather than the lvlib.
(952 Views)
Accepted by ImreSzebelledi
I have just checked with Labview 2020 SP1 and the bug seems to be fixed in that. The example builds just fine.
-Imre
(937 Views)
