06-28-2005 01:41 PM
06-29-2005 05:41 PM
07-30-2005 07:29 PM
08-01-2005 06:28 PM
Hi Eric,
The "Disconnect type definitions and remove unused polymorphic VI instances" option is located under the Application Settings tab of the Build Application configuration window. Please let me know if you have any further trouble finding it!
Kind Regards,
08-01-2005 09:15 PM
08-02-2005 07:13 PM
Eric,
Ah ha! I apologize -- I completely overlooked the fact that you mentioned having LabVIEW 7.0. That application builder doesn't actually exist in LabVIEW 7.0, so that explains why you can't find it. This is actually a known bug in LabVIEW 7.0 and Windows SP2 (which I assume you're using). Unfortunately, all I can tell you is that it has been fixed in LabVIEW 7.1, so if you have a copy available to you, I would strongly recommend upgrading to it. If not, you might also try upgrading to the latest version of DAQmx Base, as that certainly wouldn't hurt and may mediate the problem.
Kind Regards,
08-02-2005 09:53 PM - edited 08-02-2005 09:53 PM
Actually, if you are using Windows then you should consider upgrading to NI-DAQmx 7.5 which now supports the USB-600X devices. You will need to convert your USB-6008 for use with NI-DAQmx using the steps in this KnowledgeBase.
EDIT: Grammatical errors
Hopefully this helps-
Message Edited by Tom W. on 08-02-2005 09:53 PM
