10-04-2012 09:09 AM
I have two LabView applications and its installers, all of them generated with the aplication builder. Both works fine: I can install them in several computers without LabView. But when I try to install both in the same computer, the result is that I only have the last application I've just installed. I want to get the two applications installed at the same time in the computer. Is it possible? Anyone can help me?. I'm using LabView 2009 SP1
Thanks in advance
10-04-2012 09:16 AM
Double-check your BUILD Specs for both target apps.
Make sure the TARGET FILE NAME is different.
Blog for (mostly LabVIEW) programmers: Tips And Tricks
10-04-2012 09:20 AM
Hi Steve.
Thanks for your repply, but the Target File Name are different. Furthermore, I am trying to install them in different folders, both inside Program Files; with different names,...
10-04-2012 09:23 AM
If I understand you correctly:
from scratch, you install A, and you get A.exe, where you expect it.
from scratch, you install B, and you get B.exe, where you expect it.
10-04-2012 09:27 AM
Exactly that. I'm triyng with several options in the Application and Installer builder, but it seems it does not work
10-04-2012 09:30 AM
It works quite well. We have installed over a dozen different applications on the same computer. I suspect you have something configured incorrectly in your installers and possibily the builder itself. We would need to see those to see what is not correct. One possibity is that your builds are generating the same GUID for the applications. Therefore even though the names are different the installer thinks they are the same thing.
10-04-2012 09:36 AM
There's nothing in principle that prevents you from installing 2 or more apps, it's very possible.
Try installing them someplace OTHER than "Program Files". Perhaps Windows is being "helpful" or "protective".
10-04-2012 09:37 AM
Thanks. Is it possible to know the GUD asigned to the app? I've created the second app form the first one; and only modify the VI's source code and the names and destionations in the builder.
10-04-2012 09:38 AM
I'll try and tell you here
10-04-2012 09:41 AM
I've just try. It doesn't work
