Application Build Error 1003 LV 2009
Hi there, im using LV 2009 on a Linux (OpenSUSE 11.1, Gnome) machine and unfortunately i encounter this known Error when i try to Build an application.
"Error 1003 occurred at AB_Application.lvclass: Open_Top_Level_VIs.vi -> AB_Build.lvclass:Build.vi -> AB_Application.lvclass:Build.vi -> AB_EXE.lvclass:Build.vi -> AB_Build.lvclass:Build_from_Wizard.vi -> AB_UI_Frmwk_Build.lvclass:Build.vi -> AB_UI_FRAMEWORK.vi -> AB_Item_OnDoProperties.vi -> AB_Item_OnDoProperties.vi.ProxyCaller
Possible reason(s):
LabVIEW:  The VI is not executable. Most likely the VI is broken or one of its subVIs cannot be located. Select File>>Open to open the VI and then verify that you are able to run it."
The existing topics couldnt solve my problem. Is there a way to pinpoint the (missing?) subVI that may cause this error or what other problems could have lead to that error?
Thanks in advance
KvanB
(971 Views)
I have gotten errors like this... did you check the obvious, that your main VI is indeed executable? If you have built this executable before, I would go to the location on disk and delete that folder. Then try building again.
CLA // LabVIEW 2016 // BALUG // Unofficial Forum Rules and Guidelines
(918 Views)
Hi KvanB!
Maybe you will find a solution here:
http://digital.ni.com/public.nsf/allkb/705C2ECA081F3C7986256C0F00559B02
Alexander E.
National Instrument Germany
(889 Views)
I found the VI ("distcal_differential.vi") in a directory of the project file and i could open it without any errors.
(868 Views)
Accepted by JÞB
"Solved the problem" by contacting the creator of the project. For my applications this specific build is not neccessary.
(857 Views)
