04-03-2010 01:38 PM - edited 04-03-2010 01:40 PM
Hi i have a app that runs in xp with out any problem , but when i try to run the same app in windows 7 it does not run see the error
( the daq board is there i see it with measurement and automation test ) in windows 7 starter
So what is going on i have no idea myselve
App is made with labview 8.6
windows is version is windows 7 starter
04-03-2010 02:41 PM
There are no guarantees that an application developed using LV 8.6 will run under Win7. Only LV2009 applications are intended for Win7.
There is still a chance that a LV8.6 app will run. What does MAX show for your daq device under Win7?
04-03-2010 02:44 PM
04-03-2010 04:58 PM
As you can see i can work with the device under windows7 under Max ,manual i can move the switches it works also
ONLY te program under 8.6 does not work
