‎02-21-2006 09:44 AM
‎02-27-2006 04:59 AM
Hi David,
If you're comfortable with the information in the tasks and objectives list here :
http://www.ni.com/pdf/custed/us/cla_tasks_and_objectives.pdf
then you shouldn't have a problem.
Unfortunately there's nothing more we can really advise beyond good programming practices.
http://www.ni.com/pdf/custed/us/cla_requirements_conditions.pdf
Page 3 refers to Confidentiality of Examination Materials, which actually precludes anyone from discussing the content or intent of examination items and this is why no-one would be in a position to reply to your query.
By signing the application form, you agree to be bound by this and other conditions, and so has everyone else who has applied for this certification, so no-one will be able to reply to your query on this matter.
Sorry.
Sacha Emery
National Instruments (UK)
‎02-27-2006 06:14 AM
‎02-27-2006 07:48 AM
I can offer general advise that does not violate the agreement.
1) Practice using the version of LV that you are going to be taking the test on. If you ar used to a customized environment, then learn how to customize it fast or get used to using the default setting. Things like "auto-guess-my-tool" etc.
2) Review the course material recomended by the req's document.
3) Make sure you are up-to-date on the latest and greatest features of the version you will be testing with.
4) Get a good nights rest.
5) Write down every thought you have on a subject.
Planning to take the test more than once is a good idea. I have seen people try it multiple times before they pass.
Ben
Certified LabVIEW Architect, LabVIEW Champion, and General Anoyance
‎02-27-2006 10:42 AM
Unfortunately, those of us who make our living working billable customer hours find taking these exams once expensive, much less multiple times. Add to it that the exams are given in specific/limited locations (I had to travel 100 miles/ 160km to take the CLAD part, another 100/160 to a different city to take the CLD part) and it is very non-trivial.Those who work for companies that have enough "buffer" to write off the time are definitely in a better position. For that reason a little more information to the structure of the exam would be appreciated, and from my experience would not invalidate the exam's testing of knowledge. I can't imagine knowing what I know about the actual exam question I was asked helping in a different problem except as an overall understanding of how the questions would be asked, which, having taken the live online prep class, I already knew. Something similar for the CLA would give me sme confidence that I might not have to take it multiple times, just to get a feel for the types of questions. As to knowing what version of LabVIEW is going to be on the machine, how would you ? A friend of mine who took the CLD exam last spring when I did failed because he wasn't familiar with the 7.x environment, not due to a lack of LabVIEW experience/knowledge, but due to his customers still working in 6.x. I have been "playing" in 8.0, but haven't done a "real" project to get comfortable in the new, less modifiable environment (as in configurable to the previous look and feel, such as 7.x is) as my customers are reluctant to start a new project in 8.0 yet. On top of it, the machines provided where I took the test didn't have floppy drives, which is the mode that we were supposed to submit our test results on (sealed envelope with all test paper work and labview code created on a floppy, to be sent directly to NI), adding to the initial stress level and causing a major initial distraction.
Didn't want to make you any more nervous than taking the exam will, just wanted to vent some annoyances that I have about the process. While I think that certification is a good thing, helps provide some indication of actual knowledge, the process seems to have some glitches in it yet.
P.M.
‎02-27-2006 10:52 AM
‎02-27-2006 11:05 AM
‎02-27-2006 11:40 AM
‎02-27-2006 11:41 AM
‎02-27-2006 12:17 PM
@"Ben" wrote:1) Practice using the version of LV that you are going to be taking the test on. If you ar used to a customized environment, then learn how to customize it fast or get used to using the default setting. Things like "auto-guess-my-tool" etc.
Can we bring along our favourite LabVIEW.INI file for use at the exam? That would save some initial setting-up time and make me more "at home." Of course, the instructor can check the INI beforehand to ensure there are no undocumented SuperSecret.... settings in there
-Khalid (Certified LabVIEW Developer).
