Any way to control two waveform graphs with boolean switch?
Hi NI Community,
I’m trying to figure out how to control two different waveform graphs using a Boolean switch. Specifically, I want the Boolean switch to determine which graph is displayed: when the switch is on, it should show one waveform graph, and when the switch is off, it should show the other.
I would appreciate any tips or suggestions on how to set this up!
Thanks in advance!
(1,175 Views)
Hi engineer,
THINK DATAFLOW: when you want to have "different code in cases" then this code belongs "into cases"…
Why do you need two graph indicators? Would it make sense to show one or more plots on just one graph?
(1,164 Views)
I understand your suggestion about dataflow and using case structures, which could be useful if I was working with a single graph. However, in this case, the college practical assignment requires two graphs, so that's why I need to manage both of them with the Boolean switch.
(1,158 Views)
Hi engineer,
When you understand my suggestion then it is no problem to handle both graphs…
(1,152 Views)
Although @GerdW's native language isn't English, he made a wonderful pun.  Try saying his suggestion
and as you approach the last clause, be sure to say each syllable clearly.
(1,109 Views)
You can right click on top of the graph indicator and create a Property Node - VIsible. THen you can wire teh boolean swith to change the property to visible or not. Do the same for both graphs and you will have what you need.
(1,094 Views)
One example among many:
The simplest solution is to send both to the same graph and show Visibility checkbox
Qestit Systems
Certified-LabVIEW-Developer
(1,072 Views)
